Pirate Power Motors
Status
Not open for further replies.
Bikeguy Joe
PIRATE POWER SPECIAL PRE-RELEASE STATEMENT
First Pirate Cycles would like to thank all of the proud Pirate
supporters for your business. It is because of you, we can bring this
wonderful addition to the motorbicycling community.
We are very proud to say this is a joint venture with contributions from
several vendors and also includes the work of a few very talented
members.
The true teamwork demonstrated here is a respectable example of how
everyone....vendors and enthusiast alike benefit from the result of
working together.
Credit goes to all of the following contributors for the success of this
project.
Pirate Cycles AKA. Justin / Troy Boy
Creative Engineering AKA Jim / Manic Mechanic
Sick Bike Parts AKA Pablo / Ghost0
Motorbicycling Members AKA FlyByTaco and Riding Rich
PIRATE POWER SPECIAL HIGH PERFORMANCE ENGINES
Keep in mind we are currently in the testing stage and these
configurations may change.
We also would like to encourage the recommendations of the community to
bring you more of what you want. Here is the lineup.
All kits will be built from the bottom end up.
You won't find the usual metal chips and dust or need to put oil in your
crankcase.
These motors will be fully assembled with surgical precision.
We are testing high end gaskets including a full copper gasket set.
All engines will have top quality Main Bearings designed for higher rpm
and tougher loads.
The standard engine case and cover hardware will be replaced with
quality socket head cap screws. ( Put away the screwdriver get out the
allen wrench )
The clutch shaft spring will be adjusted properly. ( no more messing with
that star nut )
The small end needle bearing will be the wider PK version.
The big end bearing will be the much more reliable cage-less CROWDED
version.
All engines will be fully leak tested ensuring the highest quality.
We will offer limited warranty on the main engine components and
craftsmanship.
What exactly dose that mean ????
If you rev your engine WOT with no load till the paint starts smoking
you're out of luck.
If you mount it poorly and rip it off the bike you're out of luck.
Other than that, as usual Pirate Cycles outstanding customer service
will be provided.
We will also give you your very own Pirate T-Shirt to
sport around town while all your friends try to keep up with you.
STAGE 1 high performance kit
This kit is designed for the enthusiast who is looking for a Reliable
Quality Engine Kit.
The cost is being kept to a minimum yet the quality is very high.
This motor will include all of the above.
All of that and there is still more........
Manic Mechanic Custom Billet Machined High Compression Head
made exclusively for Pirate Cycles PPS motor.
You won't find it anywhere but here.
A very nicely ported cylinder.
Hand crafted with the utmost care and precision.
We can put the punch where you want it.
High quality Billet Intake provided
by Creative Engineering. Jim big thanks! We love your work.
The clutch post will be pre-cut for clearance.
On a final note, for these kits we can supply a fitted Clutch Pulley
System to replace the standard clutch barrel for ease of use.
We will work with SBP to ensure adaptability even with the Shift Kit.
It will be possible to add the billet clutch actuator from Creative
Engineering to this motor kit. Maybe a spring run of those of
those as well? We are glad to fill the supply if there is
a demand for a product.
The clutch pulley and billet lever are offered as add on options.
Inclusiveness of these and other add on options within a kit will be
determined by demand.
EXCITED YET? WE ARE!
STAGE 2 high performance kit
Quality Engine Kit and some more power and speed.
This kit provides a very sweet performance upgrade.
It will rev higher and pull harder for those who like a little more
excitement.
The cost is being kept very reasonable yet the quality and performance
are unbeatable.
THIS IS BIG!!!!!!!!!
PUT SOME TACO Power on your bike !!!!!
This motor kit comes complete with a totally sick custom built expansion
chamber designed and Hand Crafted exclusively for Pirate Cycles.
Tuned to perfection with an extra sweet twist for that super slick look
and a perfect complement to the ported cylinder.
Thank you TACO no more pocket bike pipes for us.
Due to the addition of the expansion chamber we can more aggressively
port the cylinder.
This engine will also come with the high quality Billet Intake provided
DIDN'T THINK IT COULD GET ANY BETTER !!!!
STAGE 3 Super high performance kit
This kit is designed for the enthusiast who is looking for Extreme
Performance.
This kit provides the most awesome performance upgrade possible.
Every aspect of this kit will be tuned to perfection.
It will rev higher and pull harder all I can say is hold on and wear a
helmet.
The cost is being kept as low as possible the addition of real high
quality components impacts the cost.
No Knock Off Carbs Here. No Clones. You will get the STICKER.
The stage 3 kit starts off with a REAL DELLORTO PHBG.
We will Re-Jet and tune to perfection. No joke here.
Want more???
OK you got it.
The stage 3 kit will be the first to offer a REED INTAKE SYSTEM.
We all have been waiting for this for a long time.
The REED KIT is designed exclusively for Pirate Cycles and the Stage 3
KIT only.
It mates perfectly with the DELLORTO Carb.
What a wonderful combination.
THIS IS Huge!!
This pipe is specifically for the stage 3.
made exclusively for Pirate Cycles.
You won't find it anywhere else we promise.
A cylinder ported to the MAX.
Due to the addition of the expansion chamber, Reed Valve, and Carb we
can very aggressively port the cylinder.
Still not satisfied???
Be sure to mention anything else you might like.
We anticipate completion of testing and kit availability by this SPRING.
Check back regularly for PICS and UPDATES.
Please PM Troy Boy for any updates.
I will unlock this thread when the kits are released for sale to the general public.
A quick clarification;
motorbicycling.com bears no ill will towards piratecycles nor the engines in development, any improvement on these engine kits and availability of aftermarket parts welcomed with open arms - locked threads and punitive actions are not related to the vendors themselves or the products they're selling, but are simply the result of unbecoming conduct by affiliates.
Status
