Pillow Block Bearings Won't Spin
BeaverRat
Hello,
I got two of these for a jackshaft, but upon recieving them, the bearing inside of them does not actually spin. I put a 5/8 jackshaft into it, and the shaft just slid in the ID of the pillow block bearing without actually spinning it. Using my fingers, I cannot get the bearing to even budge. I am quite confused, does this not come with a bearing? Is this just the housing that holds a bearing? hmm...
http://www.amazon.com/Spyraflo-PB3-...O8/ref=sr_1_16?ie=UTF8&qid=1336195336&sr=8-16
Thanks
There oil lite bearing they don't spin , the shaft spins on it . Also call sintered bronze bearing or bushing . Dan
this is a pillowblock BEARING
what you have is a bushing no MOVEABLE parts in it just a brass sleeve
talk about a misleading ad...
if you see the term ""Oil Impregnated Bronze"" it uses oil as a method to prevent the bushing siezing to the shaft and not a actual bearing
It's complete , there are used for low speed application . Will not last long on a jack shaft with a key way . Dan
I wouldn't be too quick to return them, if the price was right...
Cost of mailing back will be lost to you.
Perhaps you could use them in the future for some other application???
...like maybe to support a pedal shaft, and use a quill bearing upon it and 2nd primary drive pulley with a sprocket on the inside of it to the secondary drive going to rear sprocket???
just sayin....
rc
a similar setup was used on squirrel cage fans in home furnace fans.very common,usually lasted the life of the furnace if lubricated regularily.
a hardened shaft,stops to keep shaft from moving in and out and you may get some miles out of them.road grime will cause premature failure,though.
the pillow block bearings above are more suited to your application,and have set screws or eccentric locking collars to keep shaft in place.
The reddish color of the bushing/bearing and the fact that it clearly states 'bronze' in the ad should have been big hints. There is no such this as a roller/ball bearing made out of bronze. Also, bearing is still the proper name for them. Think of the bearings in an engine.
https://en.wikipedia.org/wiki/Plain_bearing
