There's agreat selection of panniers these days on ebay and Amazon- China has really bought the prices down again to reasonable- although panniers are really more meant for touring on a bike- I had a couple on a month ago, and with a front basket- I really had quite a bit of stuff from the store, and room for more-
but panniers are not as practical and are a little risky for shopping- I'm still going to get some saddlerbag baskets- but haven't decided if I'm going with a standard wald design- they have 3 basic designs, or going to fashion my own onto a blackburn rack I have already-
fashioning my own would be the lightest setup, because an alloy rack saves a lot of weight comapred to the same part of a steel wald basket- the baskets are heavy and then full of stuff can be really heavy-
Basket makers carefully DON'T make saddlebag sizes like that- but two front baskets are only slightly wider than at least two of the Wald saddlebag baskets, and would carry just as much- sunlight makes some front baskets a bit smaller and slightly cheaper- if you already have a rack especially, two front baskets can be a cheaper alternative
http://www.ebay.com/itm/BASKET-WALD...prg=1005&rk=3&sd=400322499008&#ht_1261wt_1602
http://www.ebay.com/itm/BASKET-WALD...ltDomain_0&hash=item5d4115268d#ht_1261wt_1602
http://www.ebay.com/itm/BASKET-WALD...ltDomain_0&hash=item53fada7b80#ht_1261wt_1602
The three Wald models are also on Amazon and prices vary so shop for the best price when you buy. If you get some used, be sure they come with the front hardware, or it'll cost you another $9.
baskets can be attached to rear racks easily and safely with small worm clamps- be sure to anchor the bottom too-
You can also put a basket on top of the rear rack- but that doesn't carry as much as the two larger sizes of saddlebag baskets- (the smaller Wald saddlebag is actually equilvalent in cubic inches to a Wald front basket size, which is also then the rear rack size as well-)
and the center of gravity of the load is then higher and not as well balanced- and you have to be careful getting off the bike, as your leg tends to want to hit the basket when you swing it back over
I have a rear trunk bag of nylon for the top of a rack or saddlebag basket- and it holds quite a bit too, and at a lower profile than a top basket- cheap now from China- it cut the price in half of what it was at Wal-mart a few years ago-
http://www.ebay.com/itm/Sports-Cycl...ltDomain_0&hash=item3f1500d4f0#ht_3588wt_1004
A bike with a front basket, a saddlebag basket and with a nylon trunk bag on top of that will really carry a lot- and that's what I'm going for before the winter when I want to take as much as I can with each trip- and the set up is not that heavy-
below are some baskets I lashed to the seat rails of my scooter with nylon rope and plastic ties- they are Wald "fender" saddlebags- I got used- no longer made, but sometimes used on ebay, made to fit across fenders and I simply removed the middle hardware and tied each basket separately- You have to look closely because the baskets are not that big, and painted blue.
baskets make a BIG difference in practicality-
