I wouldn't use anything on my bikes or cars that's sold in the checkout lane at Wally World or the supermarket. That's where you'll find JB Weld.
As was already explained above; blue LocTite is removable, red isn't unless you apply heat. There'll be other opinions about that but all you need to do is search LocTite's website for their recommendations on usage of their products.
The cap screws pictured above should be available at most hardware stores or fasteners supply outlets. The engine mounts are 6mm X 1 thread. The length will be determined by your specific mounting method.
I really have to take exception here, JB weld is a WONDERFUL product IF USED CORRECTLY!
It has saved my behind and wallet many, many times.
Heck, it's worth having as long as you know how to use it.
It won't fix high temp stuff.
It won't fix gasoline stuff.
It won't repair major engine parts or replace fasteners.
Overall, I agree with you about it not having many uses on our bikes. But it will repair certain types of busted castings if all you need is air and oil tight. I've used it to stop oil leaks in dozens of japanese dirt bikes over the years where welding and cost was the alternative. TIG welding a cracked case is a major hassle because it requires total teardown even for someone like me who can easily do my own welding.
Sometimes it can be a great way to keep something near the end of it's useful life kicking a few hundred more miles.
Don't dismiss it on the basis of other peoples misuse. The product works as designed.
Besides, I once called the company after it saved me a bunch of cash to compliment them. The president of the company called me back two days later and thanked me for using his stuff personally. How many top people in ANY company these days even gives a darn about anything but profits?
JB weld is made in the USA and deserves a better reputation than it gets.
It has saved me money, time, and aggravation enough times I feel I must speak up.
Your statement was far too harsh in my experience Tom.
Just sayin'
