went to put the sprocket and rag joint on my bike and I noticed that the holes for the split backing plates DO NOT line up with the holes in the sprocket. when I put all the bolts in and tighten them up, they "flare out" on the nut side because the backing plate holes are further apart than the holes in the sprocket. It seems that it is designed this way on purpose ! is this correct ? looks like a damn onion blossom on the nut side with the bolts/nuts flared out !
Also, my genesis astra has 48 spokes, so I drilled 6 holes in my sprocket to go between the spokes. then I tried to bolt it all together with the rag joint to "match drill" the 6 holes I drilled in the sprocket but it doesn't line up. I'm a structural / mechanical engineer and this just doesn't make sense to me - bad design, or am I missing something ???
i cant seem to be able to upload the picture of the sprocket and split backing plates. The picture shows that the holes do not match.
