rcflier500
Hi,
A few days ago i rode my bike in the morning and it ran fine. In the after noon it ran ok for about a half mile and then backfired and died. The rest of the day all i could get it to do was backfire. I pulled the plug and saw it was wet. I reinstalled it and pedaled as hard as i could to clear out anything that might have accumulated in the crankcase to foul the plug. At this point it will not even fire. I took out the plug again, dried it off and checked for spark by grounding it on the head. No Spark.
I then unscrewed the wire from the cdi, shortened it to make sure it had a good connection and reinstalled, still no spark. Resistance in the plug wire is .9 ohms. I then checked for continuity in the kill switch, its working perfectly.
I then proceeded to hook up my multimeter to the magneto and by turning the back wheel as fast as i could with one hand i was able to get 2 VAC. Then connected the voltmeter directly to the plug post on the CDI and grounded the other end onto the head. Spinning the wheel made no difference in the voltmeter set to DC or AC.
I am at a loss on what to check next or even if my measurements are right. Any help would be greatly appreciated.
BTW, im using a BP6HS plug
