G3R0N1M0
All you need is
A small sheet of aluminum
A punch
A Hammer
A crack in the cement
A pair of tin snips
First I shortened the chain a link because it was to long to work with.(with the punch,hammer and crack in the cement)
Then I cut out the right size shims
To make the holes I used a punch and a crack in the cement which made this problem.
As you can the the one on the left I worked with a little more i just hammered it flat then used the punch to make the hole to the size then repeat.(I used a small anvil but you could easily just use the cement)
The shims go here.
After some riding the "blowout" flattens out and then you add more shims as needed all in all took about 30 minutes to fix the chain problem. This is a fix that any body could do.
A punch
A Hammer
A pair of tin snips
The shims go here.
