Hi folks,
This is pigeonguy. I am new. i have been fighting a stay run
problem for three weeks, I can start the engine and it
will run for about 10 seconds then die.
I replaced the mag coil and CDI thinking that might be
the fault. Same thing, run and die.
I then concluded that it had to be a carb problem.
Ordered a new carb, and you guessed it, same problem.
The ironic part is that when I first got the kit it would
run ok! Then it died on me pulling into the shop, and
now I have this stubburn failure. Kit is only 2 months
old. I need advice. Am out of ideas. Fuel mix is 16:1
Yes I have changed the plug also.............
