grizadams
Before you install your clutch handle bar lever and your throttle, replace the nuts and bolts with allen head bolts and nylon nuts. And if you do strip out the aluminum bolt on your clutch lever they are easy to drill out so don't buy a new one, just drill out the stripped bolt. I even replaced the little bolt on the clutch
lever on the motor with a allen head.
