New Centrifugal Clutch motor
dmpatanis
Hello,yestarday i received my new centrifugal clutch motor with pull start.
Because it has a centrifugal is wider and the problem is that the pedals hit into the centrifugal clutch and in the pull start.
The only think that i can do is
1)put the engine higher and the pedals is clear, but i cant move out the spark.
2)to cut the pedals and make it wider.
What do you suggest me to do???
Thanks a lot.
I cant do that because my bicycle it has 18speed (3-gears front and 6-gears back).
If i do that my speed didnt work at all.
I am thinking to do this:
Huh? All your gears should remain in the same spot. It just makes the pedals and the pedal arms stick out further.
The first question that poped into my mind was "how much wider do they need to be"? The second question is what are your crank arms made of?
