Im new to motor bicycling and im almost done with my first build. I have a blacked out 29 in onex genesis bike all set to go just have to mount chain tensioner and gas tank with feul lines. Everything else is ready to go but i have a major dilemma. the only way to move the bike forward with the back wheel to spin, somewhat freely, is to take the spark plug out. Even without it in the engine seems like its always in gear and turning over ( without the spark plug and feul tank). i pull the clutch handle in so its in 'bike mode' but its really not. i need some help because i dont no what to do from here. Anything will help!
I agree that its likely to be a clutch issue. you can try to adjust the clutch cables, but if that does not work, then use this opportunity, to open up the gear case and understand how it all works... be careful not to damage gaskets on the gear case cover. there is a small bronze flower nut in the center of the large flywheel/clutch. it works by sandwiching the drive gear between the flywheel and the front cover that your looking at...
1.return all the clutch cables to the smaller position
2. remove clutch cover.
3.take out the small screw and adjust the flower nut so that the clutch engages/disengages properly.
4.put it all back together, ride your bike for a while, and you may need to readjust the clutch cables if necessary as cable stretch occurs.
!another important note is the clutch arm. with the clutch handle in the disengaged position, and the clutch in the engaged position. the clutch arm should have the smallest amount of freeplay. it should completely engage the clutch.... the arm should be parallel with the chain line.
finally when storing your bike, always engage the clutch to remove tension from the clutch cable. and remember to close your petcock. as the fuel system is gravity fed.
![.duh. .duh. .duh.](https://motorbicycling.com/images/smilies/duh.gif)
