need some help
wan37
I have a bevel gear that is being stubborn.Trying to take it off to install a Centrifugal Clutch I open the clutch cover and the screw was off just rattling in there.So I'm glad I found it now,but the gear won't come off strip two crank puller and I put them on by hand tightening like it's say in this forum.Is there any other kind of puller I can buy beside the one that's in most kits . Thanks
Thanks I have stripped 3 now of the crank puller .I have oiled the pullers and the gear and also tighten it after hand tighten with a wrench I been very careful.I think the gear is just stubborn... I hope I get off soon. Thanks rohmell
Well when I took the gear cover off the screw that holds the bevel gear was completely off just laying in the cover I think the gear is a little twisted thats the reason why it's being hard to get off.
I also found the washer it was laying in the cover.I know it"s driving me crazy I took the gear off of one of my friends it came off easy.I really don't want use a lot of force because I'm scared of breaking something you know these china stuff.I think I might tighten the next puller a little more than the others with a wrench.Worst I can do is strip another one.Then I'll go to harbor freight.Thanks Rohmell for your help
rohmel I got if off easy this time I tighten the puller tighter with wrench it came off easy then...I think I might of messed up I pulled the woodfuf key off to but I don't how it goes back in now,maybe you can tell me if i need to use it or not?
thanks rohmell I like to here that I did want to cut the slot for the key way anyway seemed like to much work...
One other thing how tight do I tighten the bolt that holds that gear and the cc on or do I use lock tite.
