silverbear
The Boy Who Never Grew Up
I just posted the following request for help on my 1934 Elgin build thread...
http://mottorbicycling.com/showthread.php?p=414682#post414682
As a quick review, this bike will use a slow revving vintage Villiars 2 stroke engine. It revs out at around 1600 RPMs so I'm not kidding when I say slow revving. The engine crankshaft will use a pulley going to a pulley on a jackshaft. On the pedal side of the bike the jackshaft will turn a chain going to an SBP shift kit free wheel and from there a chain to the internally geared 3 speed Sturmey Archer 3 speed hub.
"This is where I need some help from you gear heads out there. I need to figure out what size pulleys to order for the engine crankshaft and the engine side of the jack shaft. In reverse order here's what I have already. The pedal driven sprocket on the rear wheel is 13 tooth. From there to the freewheel sprocket receiving the jack shaft chain the chain ring is 44 tooth. On the other end of that chain at the jack shaft the sprocket is 9 tooth.
At this time there is a sprocket on the engine side of the jack shaft (17 tooth), but a pulley is going there in it's place. And a pulley will go on the engine crankshaft.
This is way beyond the capabilities of me little brain to cope with. Anyone have an idea of what pulley sizes I need? Keep in mind this is a slow revving engine and I have a three speed internally geared rear hub. I'm not looking for great speed, but low thirties in the top gear would be nice. I don't expect to hit the pulley sizes right on the money and figure it is likely I'll need to change something to make it mo betta later on, but I need a starting point anyway. Many thanks to anyone willing to help me out here.
SB"
SB"
