my new point beach
hot rodder
lmost finished need to add disc brake front wheel. not sure if i like the 36 tooth sprocket doesn't seem to have much low end. been playing with carb bigger jet and change float level runs better but
sluggish on take off . getting cold in north idaho getting hard to ride
Sweet build! Ya your pipe is very cool but probably hurting your performance a bit. 2 strokes are very sensitive to exhaust tuning.
thanks for the reply you probable right on the pipe i built a baffle but i think it has to much back pressure it has no low end. i built the pipe on my trike but used larger tubing at the end same baffle and it runs great
Hello I just bought this bike in the red and white. Have the 80cc kit picking up the bike tomorrow can you tell me is there any problems you ran into please? I got a nice machined rear sprocket for it and real chain tensioner hot just a roller for it. I heard the same thing that don't mess with the pipe unless you are going to put a bigger carb and reed block. Any tips would be great thanks
Also I see you went with a mod front mount is that because you wanted the engine to sit that way or did you have to do that. What I am asking does it fit with the stock mounts?? Thanks
