So, since I was concerned about over revving this small motor, I was going to change the trans output sprocket and the rear sprocket, but I got to looking at it and I was able to rotate the trans 90 degrees, notch out the motor support, and just use the crank/sprocket assembly that came with the kit on the drive side.  I just bolted the 44 tooth sprocket from the back wheel to the crank sprocket.  It was challenging to come up with a decent adjustable idler pulley setup, but now its all set.  I took it for a short test ride and I don't think I will have to worry about speed anymore!  I'm still waiting on my new clutch before I really give it a test.  On the original clutch, one of the pads came unglued from the shoe, so I drilled it and countersunk a screw in it, but if that screw were to come out, it would destroy the drum, so no more testing until the new clutch comes in...
