michael5le
hi yall, i recently got a 2 stroke 49cc grubbe engine kit. installed everythiing properly and all. I got it running about twice for like 5 minutes but it was bogging down when i went to full throttle. but it figured it was because of the break in period. Anywho, when i turned it off my friend saw that a crap ton of gas was pouring out of the overflow valve. We took it apart adjusted the float, which took a few tries but i think i got it right and reinstalled. now it won't freaking start!!!!!!! When i turn the wheel with the clutch engaged the engine makes noises( piston moves and what not, sounds like its getting spark) and i can smell gas from the exhaust but it wont accelerate and it just makes this dying acceleration noise when i engage the throttle and it just slows down and dies.
I took off the kill switch, and tightened the clutch buut it won't start.
Is it clogged/ not getting enough gas (when i checked the spark plug again, it was pretty clean but wet)
should i clean the carb.
I hear air leaking from the spark plug when i slowly turn the wheel.
is it flooded, if so how do i fix such a problem
Helppppp before i hang myself!!!
