Finished the tear down, and sanded most of the frame with an orbital sander. Going to use a dremel to sand the areas I couldn't get to with the orbital. I am going to cut off the little cable guides all over the frame because I will be making some changes and want to run the cables how I want. I'll just use zip ties. I'm also going to cut off the brake mounts on the fork and frame. I will end up just using a rear brake rotor.
