well i took my engine apart to take picture for you guys only to find pitting of the head and scroing on the jug and the piston was pretty much ok
so heres my porting now
2.5mm up ex 5mm wider
2mm down in 4mm wider
fixed tran ports
2 4mm wide boost ports with 2 4mm hole in the piston
port mached with dental paper so it 100% perfectish
the the flat spot on the head was milled off so i could run no base gasket and not hit the head this mod made the bike a lot harder to start (wheel sids alot)
my new top speed with this porting was 47mph GPS and 8400+rpm "sthi tack"
im hoping with my new mod it sould it 50mph
power wise for 5-10mph a stock ht with 44 would beat me and from 10-40 im way faster and then it starts with the vibs and then gose nice again at 45+mph
I will post new pics of my new porting in a day or so
if i do hit 50mph i will make a video with gps and drive on a road beside the freeway and il only be passed slowly
fixed tran ports
