My Bike wont run,,, Again
nathanmd33
Well I was lying in bed and can't sleep. That being one of my problems I thought of another. Which brought me to my MB. Simple problem :She Won't Start
The MB has ran a lot in the past! And about 5 months ago it died and it was because the clutch needed fixing!
But Before it wont even start (now) It would normally run for about 10 minutes normal riding and then without warning just would stop like it wasn't getting a spark. But I can not figure out why. I have tried so many different things and i really want to ride it!
Someone HELP
Its a china 80/60
if it won;t start at all now, then it's back to basics - gas gone stale?, got spark?, got compression?
Magneto, then spark plug. How is your mix?
Make sure the head, exhuast and manifolds bolts are tight
I may try and replace the magneto like you said! Is it a hard fix?
Is it possible the CID box is bad?
I am going to just try a new gas oil mix
Should I run it rich to try and get her back?
Check for spark before you by,easy just a ground wire from the plug base to the engin with it out.see if it fires. You can also by a spark tester form NAPA or Northerntool.com good to have even for car work.................Curt
