MTB to motoped/Enduro/dirtbike thing
Discussion in 'Motorized Mountain Bikes and Road Bikes' started by Radar00, May 26, 2016.
  1. Radar00
    Radar00 New Member
    Apr 28, 2016
    34
    Well today I started the butchering of my old MTB.
    I was inspired by this thing. [​IMG]
    [​IMG][/IMG]
    It had been sitting in the shed rotting for the past 5 years. Has front and back suspension and I actually have two of them. Rescued from the trash years ago.
    [​IMG][/IMG]
    chopped the head tube off since i'm going to make a proper C type frame thing like the motoped in the above pic. I'm using a length of 36 in gas tube for that. and will basically just cut and re-weld the tube in the proper frame shape since bending isn't going to happen. The gas tube is like 1/8th thick.
    [​IMG][/IMG]
    Chopped and cleaned up the front forks. The irony is- the handlebars are rusted in there so I have to bang em out (eventually. For now I'll keep em together just to get a better idea when I lay out the frame over the weekend.
    [​IMG][/IMG]
  2. Agreen
    Agreen Member
    Feb 10, 2013
    786
    Looks cool! You have my attention now :D
  3. Radar00
    Radar00 New Member
    Apr 28, 2016
    34
    Not much really done today. Only really got to chop up the rest of the bicycle to get the rear tire and suspension. I laid out the frame for what I'm thinking. Still haven't decided on the engine yet. So far overall wheel base is 51in which suits me just fine. The tires are the original 24in MTB tires which i'll keep until the frame is rolling. The seat tube will come off the down tube and I'll add some gussets which will help me mount that rear suspension. Additionally I'll put a fairly large gusset between the top and downtube and once i decide on an engine, i'll figure out how to close up the frame (depending on engine size)
    Interestingly enough I have some old cranbrook front forks laying around. I'm tempted to put a large engine in this frame.
    [​IMG][/IMG]
    [​IMG]
  4. Radar00
    Radar00 New Member
    Apr 28, 2016
    34
    So after some grinding and welding and measuring I finally have something resembling a frame. It seems like nobody knows how to change a rear tire as this one's dropouts were bent so I have to torque them back into proper alignment. Next is welding the the frame together solidly. This is basically just tacked together at the moment to check for alignment. I'm going to also have to cut some 3/8 steel plate and begin making gussets for the joints for added strength and also figure out how im going to join the whole thing together. Also waiting on my engine which is just going to be a cheap chinagirl for now. maybe in the future i'll put something better in it.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    Originally this was going to be like a dirt bike but due to the length of the wheelbase, it's looking more like one of the sportsman frames. Atleast I think so. Even still with dirtbike plastics on it and a headlight it could still pass i think
  5. sbest
    sbest Member
    Nov 3, 2015
    343
    I like the idea of a backbone frame.
    [​IMG]
    [​IMG]
    Simple and rigid if the tubes are large enough.
    If your going to make the tubes larger, you might as well use them to hold fuel:
    [​IMG]
    [​IMG]
    [​IMG]
  6. sbest
    sbest Member
    Nov 3, 2015
    343
    Another nice design that only needs pedals:
    [​IMG]
  7. ezrider
    ezrider Member
    May 18, 2016
    121
    And mine too !!
    _
  8. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    The motoped concept is of interest to me, too. That pedal/jackshaft arrangement looks like the weak link, though. Also I don't see any reason to use 26" MTB wheels and tires, as the Motoped does. Another weak link. Both problems can be solved, IMHO, by using a moped wheel and 17" trail bike tire (CT90, etc.) on the back. Probably on the front too.
    Seems a shame not to use some kind of small motorcycle engine, complete with gears unless you are trying to remain legal in a state that doesn't allow gears on a motorized bike. Even then you can get a single speed, 50cc clone of the Honda horizontal engine.
    Another option would be a small-motorcycle 2 stroke engine. Maybe an RM80 or similar.
  9. Radar00
    Radar00 New Member
    Apr 28, 2016
    34
    Since I posted this I've kind of scrapped the frame I originally built and am looking at buying a junked dirtbike/moped frame and then modifiying it. I'll post more as I find a frame thats suitable
  10. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    You might consider starting with a Honda Z50, XR50 or CRF50 frame and building on that. It is a backbone frame that is designed for the horizontal Honda engines, and the clone engines from 50cc all the way to 160cc are designed specifically to fit it. Put long forks and swingarm on it, add some 17" wheels and you're almost there.
    I built something similar using a Honda XL70 frame, longer forks and swingarm, and 17" rear/19" front wheels with a 125cc clone engine. I ride it everywhere and have several thousand miles on it. But a 50 frame might be an even better starting point.
    Here's my little bike:
    [​IMG]dnut
  11. ezrider
    ezrider Member
    May 18, 2016
    121
    Whats the specs on that ?
  12. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    It weighs about 200 lbs, I guess. 1974 Honda XL70 frame; early '80s XR100 swingarm and forks; tank, bar, seat and fenders from a 1981 XL80, front 19" wheel from an early '70s XL100, rear wheel (with overlay sprocket for a mountain gear) from a late '60s Trail 90. The engine is a Jialing/SSR 125cc with manual clutch and 4 speeds. It gets 80+ mpg if I run it like I'm trying to kill it, and over 100 mpg if I putt around at 25-35 mph. It is tagged and street legal.
    I'm thinking about putting a 140cc Piranha engine in it.
    dance1
  13. ezrider
    ezrider Member
    May 18, 2016
    121
  14. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    CB100 was a neat bike. So was the CB125. Sym sells a 150cc clone of the CB125, called the Wolf Classic. I have more fun building my own stuff, though.:-||
  15. ezrider
    ezrider Member
    May 18, 2016
    121
  16. WECSOG
    WECSOG Member
    Nov 10, 2014
    118
    That is a nice bike. I thought it was pretty funny though when he said he had only put a couple hundred miles on it because he had only had it a couple months. In southern California where it's always nice riding weather? I'm pretty sure I would have a couple hundred miles on it before the first weekend!
