Hey guys, I am just starting work on building my first motorized mountain bike. The bike is a vertical pk7
I have an engine from a weedeater lawn mower it is a 4.5 hp briggs and stratton 450 series motor.
I also have a 70 tooth #40 gear for the bike and a 11 tooth gear for the motor. I am not quite sure if that is geared low enough with just that but I have been looking into jack shafts and have not found a cheap option to lower it more, and I am thinking I may try it like that and see how it works. I think it was coming out to about 10mph at a little over 1000 rpms. I am planning on trying to mount the gear on the opposite side of the bike as the main gears so that I can leave all the other gearing alone and it will not make the pedals turn when powering the back wheel from the other side. Also this will allow me to have the motor somewhat centered over the wheel wheras I would have to have it way over to the side to get the rotation in the correct direction for the other side. I am still looking for a good method to mount the main gear on the back wheel, I found some adapters on pirate cycles but $50 seems expensive does anyone else have any other options they have used? I also am planning to build some sort of rack over the back wheel to mount the motor on. I will post pictures as I work on this, hopefully it will be a success.
