Cowboy Rider
Howdy Folks,
Seems I've stripped out a couple of studs for the Engine Mounts. The nuts will NOT tighten up anymore, and in fact they won't even back off the studs. So.... I pulled the studs out of the cast engine housing Nut and all. (I should say that I "Threaded" them out, thankfully the cast part isn't stripped!)
Anyhow, the closest I can get to the Proper thread size and pitch with my Tap and Die set is 6mm X 1.0 Thread Pitch. But this isn't quite right. When I run my die down the threaded stud that I removed, it doesn't look like it's cutting the new threads quite deep enough. A single spare nut that I have in my kit will thread onto those new cut threads on that stud, but it seems a bit sloppy and will likely not hold up to a bit of torque that I think I need to keep the engine good and Solid onto the bike's frame.
What I aim to do here is Replace all four Studs and Nuts with some good old American Made materials that I think will handle a bit of torque without stripping out. (I know, I need to remember to exercise a little Restraint, so that I do NOT strip out the cast part - that would be BAD!) I also intend to apply a good Thread Locking compound to at least the studs (into the cast) and maybe also the nuts that run up to the motor mounts.
So.... Does anyone here know the proper thread size and pitch for the new materials I need to get?
_____________________________________
Also, since I never really had a problem with the Studs into the Cast... should I even apply the thread lock compound there, or do y'all think that just using it on the nuts alone will be enough? I should Note that the Rear Mounts are the only ones that have been the problem and that the front ones still seem nice and Solid. I just figured that I ought to replace All Four since I'm getting this far into the job.
FWIW, I'm quite Confident that if I get this mounted up here nice and Solid, I'll never have another complaint/issue regarding the typical Vibrations that are so well known with these Engine Kits. I'm pretty certain that those stripped rear mounts have been one of my biggest running issues with this bike. At any rate, I post this question in the hopes that I'm correct in my thinking and also to see what you guys know and hopefully learn from some others that have a lot more experience.
Thanks Folks!
Thanks Folks!
