jolfstn
I ordered some lights to use as turn signals, and it turned out the rear lights were LEDs and the front were incandescent. I have a standard 2 pin thermal flasher and an on-off-on switch from a cheapo bicycle signal kit to use. The standard ones work fine with the flasher, but not the LEDs. I've read one could add a relay and the LEDs will then draw enough current to flash, but I couldn't make the one I bought work. Then I discovered a schematic that works without any assistance. Check this out: Positive battery terminal to flasher, to center wire on switch. Left switch wire to positive lead both LED & Incandescent lights (front & back, left lights) Right switch wire to positive leads LED and Incandescent lights (front & back, right lights) Negative leads from all lights to negative battery terminal. Because the LEDs are sharing the standard bulb's current, they flash in unison on the selected side! No Extra Hardware Needed! Now to mount it...
