Mcculloch Roadrunner
mrhite65
36
KANSAS
I found a Mcculloch Roadrunner but, It doesn't say what the cc's are. Does anyone know if it will be big enough for the friction drive?
I got it for $10 and it looks pretty new. It has an issue where it runs for a little bit but then dies. I figured it was worth $10 to figure it out.
deacon
minor bike philosopher
Jan 15, 2008
8,114
9
north carolina
run some carb cleaner though it.
1.pour out all the gas in it.
2.put in about two ounces of premix (oil and gas mixture)
3. shoot in a half dozen good squirts of carb cleaner.
4. Pump it through with the bulb a few times.
5. Remove the spark plug and pull it through a few times.
6. Empty the tank and add a couple of ounces fresh gasoline. See if it will start. if not shoot a few squirts of carb cleaner and do it all again.
7. usually that will do it. Not always but usually. Before I rebuilt or bought a new carb I would try it a few times.
I dont know the cc of the engine try google they might have a listing for the specifications.
mrhite65
36
KANSAS
That exploded view doesn't look right. The one I have has the pull start on the front. I also noticed on down that it says running time is 35-45 mins. Does that mean it will only run for that time period?
deacon
Jan 15, 2008
8,114
9
north carolina
I bet it is cause shoes says she does ten miles on a tank and that would be about half and hour or a little more
mrhite65
36
KANSAS
Well, I don't know what happened to my last post but I'll do it again. I messed up! The name of the WW is Mcculloch Roadrunner III. Do you have the actual site I can get the info on?
