Magneto air gap?
John the Chimp
Ive read alot on this. Everthing says that its not adjustable.
Mine seems to move quite a bit. It seems to move about 1mm each way.
So what Im wondering is what is the proper airgap setting? Or whats the easiest way to set the gap?
are you reffering to the spacing between the magnet and the coil?
...if so the easiest way i've found is to wrap a business card round the magnet, then tighten everything down- should work just fine!
