cumminsbayou
I lost my clutch pin in my 49cc china 2 stroke when my clutch lever plate broke. does any one know where i can find one or can i make one?
And be sure to pack the hole in the sprocket with grease before you replace those parts. The grease lubricates and will keep those parts from falling out.Cut the base of a 5/16" drill-bit to 1". There's also a 5/16" ball-bearing in there...makes sure you haven't lost that too.
For your future reference: it's called a bucking-bar.
I concur. Aluminum, even something like T6 won't work, at least for very long. There's too much pressure from the clutch spring against it.Aluminum is too soft for a bucking bar. Use 5/16" OD steel bar.
The bars can vary from a hair over an inch to about 1 3/16" or 28 mm
Better to start off long and grind to fit.
Cold rolled mild steel will work but a drill bit is your best option. The problem is cutting a drill bit. That's some hard steel. You'll need a high speed cut-off wheel or grinder. A Dremel will do it but you might go through a couple of wheels.
I had no idea they made those, I'll look into that for sure! I thought a bike shop would only have cable ends
On a side note, that brand new bucking bar I made... didnt help, my clutch arm is, again already, touching the cable guide... I need to get that bearing out so I can put a new one in.
Unless someone knows of a way to force the clutch guts more to the sprocket side. maybe tightening the flower nut with the clutch handle pulled all the way in doesnt allow the clutch arm to return completely? I've tried tightening the main clutch spring, and loosening, and felt no discernible difference in clutch handle pressure. as far as I know jamming a screwdriver into the retention ring and pushing the bike forward will tighten it (and as far as I can tell, it does, as it brings the retention ring into full view) through the cable guide hole
Having just gotten VERY intimate with the clutch shaft on my engine, I have a couple thoughts. First, pushing the bike forwards loosens the main clutch spring. Righty-tighty and all that. Go too far loosening it and you'll foul the spring retainer on the clutch side bearing, possibly pushing either one out, which brings me to...
2nd, the clutch shaft is only retained by the bearings. If the action of the arm pushing the bucking bar (and fighting the spring tension) is enough, or if the engine case around the bearing has failed/wallowed out, it is possible to push the entire assembly to the clutch side. That how it's removed without splitting the case anyway. You'd probably notice it though. The clutch hub wouldn't line up the the small gear, and your chain would probably grind the case on the sprocket side (depending on size of chain and severity of the offset), not to mention the entire clutch grinding the right-side cover. One thing to try is careful use of percussive maintenance and see if you can move the whole thing over to the sprocket side by taping/hitting/smacking the flower nut. A safer way would be to remove the nut and clutch cover, thread on the gear tool and hit that instead with it's small bolt installed but not touching the pin. Don't hit the end of the clutch pin, you'll peen it over and never get a nut on it again.
I just thought of this too. Remove the sprocket cover and see how far you can push/pull the shaft. Mine only makes a slight click when it hits either bearing and probably moves less than half a millimeter.
Here is one of the best threads regarding proper clutch adjustment > http://motorbicycling.com/showthread.php?t=22726
In short, do not start messing with the flower nut until you have a firm understanding of the clutch and how it works.
