About a week into having my bike up and running it would start to die after 5-10 minutes of running. I checked the plug and it was dark and wet so I changed it and the bike would run again for a day or two and the same problem would persist. I changed the clip on my slide so it would run leaner and the plug no longer gets wet but the bike still dies out after running for a few minutes. I've checked the carb and it does not seem to be flooding and I've switched my CDI with a friend's that was working and the problem persisted. The head bolts are tight, but the exhaust port leaks oily sludge at the bottom because the stock gasket is rather crummy. Everything is stock except the plug which is a Autolite 4093. If anyone has any ideas as to what I can try next it'd be much appreciated, i'm out of ideas. I can provide pictures if that helps too.
Update: I dropped the clip on the slide down two slots and tightened the plug a bit and it runs better but still tugs at high rpms or going up hill.
