LIFAN 2.5 HP Engine on bicycle
darkcobra94
13
louisianal
I previously owned a 4 stroke bicycle engine kit, and now I have been riding around my 2 stroke engine! It's a lot of fun, but I'm looking for the smooth ride I once had before my other engine's clutch crapped out and I ruined the engine.
I noticed that homedepot is selling this 97cc engine
http://www.homedepot.com/p/t/203281925?productId=203281925&storeId=10051&langId=-1&catalogId=10053&cm_mmc=hd_email-_-PP_OMS_Ord_Conf-_-_PP_OMS_Ord_Conf-_-pip_203281925__W176393372#specifications
My question is, since I have the 4 stroke mounting plate that I was used with the HS engine, could I put this engine on a bicycle?
Also, what would I need? What kind of clutch could I used, mounting brackets, and throttle?
BarryT
83
Corpus Christi, Texas
Yes, this engine should fit well in an in-frame build HOWEVER, if you order the 97.7cc HD will send you a 79cc. I've just gone round and round with them, they ended up giving me a 10% discount. Check out this gear reduction for some ideas:
[/IMG]]
