I blew the second mag side seal this week so I decided to replace all of the bearings, I already knew that the mag side bearing did not have the outside bearing factory seal. Also for some reason the people at grubee removed the inside seal on both clutch shaft bearings. The first picture is a crank bearing the second and third are of a clutch shaft bearing. The crank bearings need the outside factory installed seal left in to help control crankcase pressure, the clutch bearing should be left sealed. With the inside seal removed the grease can liquify when hot and flow out of the bearing leaving it dry.
