Large seat tube.
Ursus
I,m currently mounting a raw motors 80cc to a gary fischer MTB. The seatpost tube is very thick and the down tube is even thicker. Would i get away with using an exhaust u clamp on both tubes? I just want to make sure the engines foundation will be strong.
I am building mine on a similarly thick frame
Even the seat post needs a large frame adapter
the front tube needed one of Sick Bikes adapters, which does use an exhaust pipe clamp
It would b easy to use an exhaust clamp only by simply drilling holes to match the mounting studs and then using either the supplied U bolt , if it will fit, or a larger version of the clamp that comes in the kits
http://www.custommotoredbicycles.com/yahoo_site_admin/assets/images/IMG_1200.28784829_std.jpg
Because my frame is aluminum i wanted as much mounting surface as possible so I substituted one of those clamps and used two bolts to mount Sick's mount
I used that set up for the large seat post
It would work on the typical large front tube on most new cruisers
For the back I substituted that clamp for the exhaust pipe clamp u bolt in the Sick Bike mount
Sick Bike Parts
You could also just drill the clamp part to fit the engine mounts and use the clamp on the back side instead of buying the motor mount
I hope you uinderstand that, I'm not good at explaining these things
