Kill Switch :(
Friction
I need some help on making a kill switch for my ww bike
what kind of switches could i use?
and
What kinda voltage range switches do i want to choose from? dance1
You can make one from a simple strip of metal grounded out to the bikes handlebars or frame. Any push button type will work as well as any on/off or momentary switch.
All the kill switch does is ground out the ignition.
I let the clutch out to kill my engines, and the switch goes in the trash where it belongs.
well i have a switch at home and i think its rated 12v my dad said it woz for a car or a pickup so ill try that might work! dance1
So all i do is connect the kill switch wire to one of the terminals on the switch and itll work??
am i right? dance1
the whacker will have a switch on i. I ran 2 wires back to that switch and wired them to the screws on the switch. Alternately, the wires on that switch will go back to a wire on the magneto and to a ground point on the whacker. And most any car switch should work, I like the momentary switch because it's default is on
