Kickstart fabrication/customization for motorized bicycle?
nimblebee
Kickstarts aren't really necessary, motorcycle that I ran the snot out of had kickstart, but was seldom used, because having push button start was more convenient.
Nevertheless kickstart was appreciated, for having an additional option in case of battery issues, & still being able to get started.
My motorized bicycle HT CG 80cc 2-cycle kit build lacks pull cord start addition, because would have need for wider pedal spacing to clear increased width of pull start kit.
Idea of kickstart is kind of interesting, but probably not necessary, since there's plenty of videos showing how to use pedals to kickstart a motorized bicycle.
Making "kicking pedal" process less awkward, my MB has center kickstand, which lifts front wheel off pavement. Rear wheel can be lifted off pavement, via forcing front wheel down onto pavement (like teeter totter). Believe process would be advantageous over having to lift up rear wheel of MB while simultaneously kicking pedal for kickstart?
Nevertheless for tinkerers, experimenters, fabricators and customizers, the idea of challenging oneself to create kickstart for a motorized bicycle can be quite tempting.
Hold my beer... what could possibly go wrong?;->
I will continue researching others efforts on forums but this is probably Pie-in-the-Sky kind of a thing, that's more fun to think about, than to actually accomplish, because it looks like a bit more challenge than most of us would agree to or complete.
For the fun of discussion, looked seeing what sort of affordable kickstart kit could be morphed/customized/fabricated onto everyday standard HT motor?
Considering: would run into same restrictions with pedal clearance as occurs when adding pull cord start to motorized bicycle?
Went ahead and ordered kickstarter kit, to throw into my spare parts box, if ever get too ambitious with too much time on my hands LOL:-).
Kit was cheap at around $13, affordable enough to have parts on hand for "what if daydreaming", whereas in the real world, unlikely ever going to happen?
It'll be interesting to see what you do with this.
Like as not, kickstarter kit will remain sharing space in spare parts box, lol.
Even so, will likely inspire various designs and ruminations, unlikely ever to see shape in physical form :)
More likely than not, effort will be expended rather for affecting best pedal kickstart methods.
Everything needed is already on MB for kickstarting using pedals.
Figuring out best method to make pedal kick happen, without my arse winding up plomping down beside MB could be problematic LOL ;-)
Kickstart kit for motorized bicycle arrived and placed in spare parts box, until and when decide to do something with it.
Also went ahead and ordered pull start kit for motorized bicycle, which goes into spare parts box, until determine how, when, & why adding pedal shaft extension kit to obtain sufficient clearance with which to allow tinkering & adding these accouterments.
Motorized bicycle with pedal start, pull cord start, and kick start be like a man wearing overalls, a belt and suspenders! LOL :-)
LA Hover bikes has a video showing installation of pull cord start and installation of pedal shaft extension kit. Unhappily, pull start kits haven't best reviews for longevity, due to insufficient quality of parts and materials chosen:
Haven't done this exact build, but for a fabricated kickstart bracket the fit matters more than the cutting. When cutting steel tube, mark around it with tape so the cut stays square, and deburr both the outside and the inside edge afterwards so parts sit flush and nothing snags. Drill pilot holes first, measure twice against the frame, and use bolts with lock nuts or thread locker, since vibration loosens plain nuts.
