Lay'emLow
Hello All,
This is my first 4stoke and first non-kit build. Seems like I dove in head first on this one. That being said, Im trying to keep the build as simple as possible using whatever parts I have lying around my garage.
The frame was a step-thru cruiser to which I added suspension disk-break forks. It took a little bit of modification on the fork tube and bearing cups to get the forks to fit.
I cut out the top of the two downtubes of the girl's frame and then preceded to weld in a slotted motor mount plate. To complete the frame, I cut the spare downtube in two and welded the two pieces back in over the motor creating a spine and the lines of the bike I am going for.
I went through a few configurations before I got the jackshaft mounted in an optimal location. The next few pictures show how the drivetrain is setup. A Hilliard clutch engages at 1800 RPM, just over the 1750 idle speed. It drives the big reduction sprocket at a ratio of 1:6. The drive sprocket on the right side turns a 5 speed wide range (14-38 tooth) freewheel with the help of an idler sprocket. Im hoping with a 26" wheel, Ill be able to take off from a dead stop as Im not using pedals on this build. Someone PLEASE tell me if my assumptions are wrong.
Future plans for the bike include a lay back seat, a jockey shifter, flipped mustache bars, plenty of chain guards... The paint will be an oxblood frame with black eveything else and tan leathers. I would like to get a float bowl carb and build a nice tank, but I cant even imagine how it would follow the frame's lines at this point. Im also contemplating a short rear fender molded into frame.
This should give you an idea of what its looking like thus far. Ill welcome any input you all may have, please dont hesitate.
Paul
Paul
