mogollonmonster
Ok I stepped up the jet size I'm now one size up from where I started, which is .0292. Starting with the needle at the leanest setting (highest groove) and worked up from there. At the richest setting, it was gutless, wouldn't idle, just blah. One setting up the needle (leaner), it idled, but still running rough, four stroking. Should I go a size larger on the jet and look for a sweet spot on the needle? I'm assuming that's how yall do it?
All carb issues aside, I did what I could to tighten down the manifold bolts, as replacing them and checking for casting slag was how I discovered my leaky gaskets. My gasket sealer was trash so tighten down was all I could do. Could the leaking gaskets be the real cause of my problems?
Lets say my carb is tuned perfectly, could the gaskets be causing the issues? Perhaps a leaking intake throwing off air-fuel, while the exhaust is causing a possible loss of compression?
