Is it ok to ride the clutch?
Datboi
So i mostly use my 2 stroke 80cc off road on the hills etc. Often the engine lacks power uphill or to pull from a dead stop uphill and stalls.
With the clutch slithly pulled in (riding the clutch) i manage to get up, how fast does this wear the clutch out? Is it something I can do without exaggerating or should it be avoided completely?
Also what modifications can I do to have more climbing power when I ride in rough terrain and hills?
I couldn't care less about speed as long as I can do 30km/h I need acceleration and torque
curtisfox
5,515
2,430
minesota
You need a bigger rear sprocket, lowers the ratio, but gives more climbing power, what size do you have now? Also have you been pedaling to help?......Curt
Datboi
I do pedal to help but I would rather not, its really hard to pedal. When you're driving over a hill over rocks and gravel without suspensions...
I have the standard rear sprocket
curtisfox
5,515
2,430
minesota
Need the teeth count, but sure you will have to get a bigger one, or your clutch won't last long...........Curt
Corson1183
10
17
Norridgewock, ME
I believe the standard sprocket size is 44 tooth, I suggest getting a 56 tooth with a hub mount so u don't warp ur rim and if u lower your tire psi about 10 pounds it should ride a little smoother over rocks and gravel.
