i had 3 pull start that i broke each of them last for about 200pulls, now im thinking if its worthy to buy another one for $20 that will last for 200 pulls about 1 1/2 month, everytime i install the pullstart i always grab the socket 1/4 wrench to remove the nut and install the aluminum thing on the magneto. im just thinking about what if i tried to use ratchet wrench to start the engine or modify the original cover of the magneto drill a hole on the cover and put 2" extension for the wrench ,the 2"extension will stickout on the cover of the magneto and whenever you start it always bring a wrench w/ you , or use a portable battery operated drill which has high rpm ,or impact wrench ,or an A/C drill or whatever is available. i gonna try this now and see if it works........you can also modify a kick start by using a ratchet wrench and make a little pedal and drill it on the end of the wrench.....
