I'm really confused...
Rusty_Nail
Sorry to have to post so many questions on here, but this forum is my only source of help and no one that lives in my area is into this hobby. So I'll get to the point. I was out riding Saturday last week, and once again felt what I would describe as a "pop" from the engine. It is still in the break in period and this time running the 16:1 mix. It's not even halfway through the first tank of gas yet and this happened. I've been very careful not to go over 1/2 throttle(only about 20-22MPH) and only been riding around my neighborhood. But after I heard the pop, engine was still running fine. The pop was not followed by a jolt like the last time. I have no clue what's going on. Other than a crank bearing what else can cause a pop from theses engines? Haven't rode it since last Saturday. As per my previous post, last engine I had "popped" and had play in the small gear connected to crank. So that's why I'm pretty sure a crank bearing went out on that engine. Since these motors are so cheap, It was just easier and less headache for me to buy a whole new engine. I've already looked on Amazon, eBay etc. If it comes down to it, I'm willing to pay a bit more for a better quality engine. Could someone possible post a link to a recommended engine or could anyone offer some advice? Thanks!
That is a possibility. Since the drive chains are cheap, I got a new one. Just need to remove some links and put it on. I wouldn't be surprised if the chain is at least part of the problem because that chain has been on several engines. It was the same chain that was on the first engine when it went "pop". I never really seemed to have alignment issues but it is a good chance that chain is damaged and just can't see it visually.
So I was just curious and was looking at the old chain. It seems to have a good amount of side to side play compared to the new one and one of the links isn't super smooth when it pivots. I wonder if its possible for some of the pins to slightly bend causing extra play? Took it on 2 short rides on the new chain and so far so good.
If you don't think the chain was trying to jump the rear sprocket, then I'm guessing the chain tried to bind inside the engine case.
The chains that come with the kit's will not last unless the kit seller says it's a 415H there's going to be trouble. The two I have had always wont to come apart. You could look at the Spark plug and even see if you got any water in your gas.
