Donavan321
Okay, so my new engine is still in break-in....running a 16:1 ratio. Gets great spark, runs awesome(does bog a little when revved) with no power, as soon as I let out the clutch I can't get going far....now the first day I started everything was fine...my c clip WAS at the 3rd notch from the top, moved it to the 2nd....a little better but no, moved it to the way top, EVEN worse. I have about 119-120 lbs of compression( I rode the bike about 10 mph and popped the clutch TWICE and the reading stayed the same. I've tried 3 different spark plugs, same results. The clutch is NOT slipping, I'm running a SPEED carb(came with the kit). I do have some regular NT carbs I could try(I'd need to steal the gasket) Of course....this is NOT my first build, I've worked out every probable bug EXCEPT trying a different carburetor. Any ideas would help, thanks! Oh, and gas is BRAND new and fresh. No air leaks either.
