Msiert
Just a heads up when doing a valve lash adjustment. When you put the valve cover back on use a new gasket making sealant to seal up the valve cover to the head.
It has been a number of years (7) that I had done a valve lash check so this week I did it. The last time I did them I set the intake at .004 and the exhaust at .006 and after 7 years they changed to .006 intake and .008 exhaust.
After the change back to .004 intake and .006 exhaust I took it for a test ride and after about 10 min of riding the idle started to surge and than drop so low it would stall out. But after adjusting the idle screw up (quite a bit) and giving it a lot of throttle on the way back I was able to get home without doing the walk of shame.
The next morning I took off the valve cover that I didn’t use any gasket seal on (relaying on the old sealer) and check the valve lash which had not changed and than I reinstalled the valve cover with a RTV Blue gasket maker and took it out for a test drive later that afternoon and didn’t have any problems.
There must have been enough air leaking through the old valve cover gray caulk gasket to cause the idle surges.
