Using "The Dragon Lady", a dual-engined girlie cruiser to commute 12-mile roundtrip to work. Mostly flat ground with two medium hills I can easily handle.
Bike and fully loaded rider weigh 300 lbs.Aerodynamics is challenged by full front basket and rider with raincoat always on. Raincoat needs to be worn.
Twin 2.2hp Mitsubishi engines on friction drive. Front has 1.375" roller; engine screams at 10,500rpm @ 38mph. Stock exhaust, flame arrestor removed.
Rear engine has 1.5" roller; engine buzzing at 9600rpm with ADA S1 expansion pipe.
Redline/peak hp rpm is probably 8900rpm.
Extreme rpm at WOT(wide-open-throttle) at intervals only on a 2-mile stretch of highway. Riding in commuter traffic. Claiming the curb lane.
I can keep up with traffic. I just want to be able to maintain 40mph for a safety margin.
When not buzzing at insane rpms, engines and I are cheerfully humming along between 20-25mph. That's at 6900rpm-front engine and 6300rpm-rear engine.
Engines have never protested but I'm pushing my luck. I need to change something so I don't kill them or wear them out prematurely.
The simplest and zero-cost solution is to switch the rollers front to rear. Rear engine location is the quietest and the screaming engine can suck on the expansion pipe as a pacifier.
Next option is to buy a second expansion pipe for the screaming front engine. However, exhaust must be rerouted; if not the fumes blow constantly in my face.
Another choice is to buy another 1.5" roller to drop engine rpm. Cost of roller and, drum and spacer w/shipping is $120. Local machinist charges $80 to loosen the drum.
Staton charges $12 for a pair of bearings. I bought TEN on ebay for $30, including shipping.
How about carburetors, tuning or air filters?
Maybe offset timing keys to shift power to higher rpms.
I realize the powerband would shift and I'd lose HP and TQ at the low end ...
but I have TWO engines so power loss is not an issue.
An EXPENSIVE and labor-intensive option is buying a 4.25hp GP 460 engine..or two. Clutch issues can be solved with 3000 rpm springs. However, I'm doing research on them to see if they're dependable and reliable.
Any ideas, fellas?
I am SO close to 40 mph. That's as fast as I wish to go.
Honey, it's just a bicycle. and i REALLY need it to excercise, and to ride it to work.(hehe)
Any ideas, fellas?
