You don't say if you are running LiFePO4 or SLA.
I had similar issues with two ebikes..
The factory Currie 250w hub motor bike has a push on / push off button (and pas/tag) on
the handle bars.. Water in that will make it do strange things, inc refuse to turn off or on.
My converted SLA bike with 45A BMS and 40ah LiFePO4 got some water into the BMS and
I am pretty sure the balance circuit saw a drain across a few points and refused to enable output to the PWM.
Rinse with isopropyl, denatured is no better or worse, just messed up so you can't drink it.
The higher % iso you can get is better. Air or rice dry and try then.
I would discon the on/off sw etc and try via a jumper wire to turn bike on (if it's a soft
sw like my hub motor bike)
