I need a lot of help but I'm excited
Smokoatay
http://www.wayfair.com/Schwinn-Mens-Lakeshore-Cruiser-S4012A-YZ1208.html
http://houston.craigslist.org/bik/3947936652.html
http://houston.craigslist.org/bid/3945484281.html
http://houston.craigslist.org/bik/3939767732.html
http://houston.craigslist.org/bik/3917513478.html
I know this is a lot to look through bu I could really use some help picking which would work best for which engine. I have no experience with this and if someone could tell me which engine kit I should get that'd be great. I need it to be easy to do, very easy.
Bikes are personal preference but some are much better than others. I would go with the first or last, multispeed bikes. They have a front brake. The rear hand brake means you will not need to deal with torque arm interference with the motor sprocket (from the coaster brake). Just my opinion.
I like wheelbender's picks.
But I'm gonna give it a twist.
I'd recommend getting something like those Schwinn cruisers, but look for a Huffy. (A Huffy over a Schwinn? Am I crazy? No. The Huffys come with thicker spokes and, seemingly, tougher wheels. And that's important.)
Even if you pick a single-speed you can always add a front and rear rim brake.
Re-enforce the fenders To find out why, just start reading these threads.
That's good advice in any case. Click on any headline that looks interesting. Read until you've finished or lose interest and then click on another. Over and over again.
You'll learn things that you need to learn if you want to be successful.
I don't want to be discouraging. This is not all that hard at all and it's very rewarding.
But you need to be able to handle a wrench. You don't need a lot more knowledge or skills than that. But you need some. And you need to apply yourself.
So, is it easy? It depends on your definition. But I say, yes it's pretty easy.
It's not 'slap it on and ride forever'. A successful motorized bicycle owner and rider has a 'relationship' with his/her bike. But it's worth doing.
Read, read, read and then read some more.
You won't be sorry.
As was stated above, "bikes are somewhat personal". We have over 40K members here and if every one responded to this question you'd get about 30K opinions on what is the "best bike to motorize".
You need to examine your needs and riding style to decide what bike is best for YOU. A few key points that you'll want to consider is the construction of the frame, strength being foremost, brakes and rim/spoke design. Some bike frames lend themselves readily to motorizing, some don't and require custom fabricated engine mounts or other modifications that require some mechanical skills.
My advice is to select a few different bikes then use the search feature here, type in the bike name and see what others have done with, and any problems they might have encountered with that particular bike. For the most part almost every bike you can think of has been covered here by at least one member or many.
Good luck and welcome to the forum.
hi, im new here can someone tell me how to make a post? thanks.
You just made one.
Select a subject area, in your case the 'Introduce Youself' section would be a good first choice and post just as you did here. Tell us a little about yourself and your motorized bike project.
To be honest, having a Huffy with caliper brakes and steel wheels, this damn thing is HEAVY.
I think either of the Schwinns might be better suited as the wheels are a tad lighter and the brakes are stronger. I think my rear wheel fully loaded is pushing 8 lbs.
Just something else to consider. Don't get me wrong tho, the steelies will hold up to some rough stuff. :D I just now need to get my front wheel trued.
Smoko! Welcome to the forum. You will find all the info and help you need here. Do a lot of reading, take your time, and don't short-cut anything. I spent months on my first build and nearly a year on the second. The information here helped me avoid making many mistakes along the way and I have had a great time with these bikes and made a lot of friends here on the forum and in person with many others.
Good Luck, Dan
What are the bike size limitation for a basic China girl 49cc engine? Do the tubes have to be a specific size? Or are the mounts pretty modifiable?
