Hub adapter bolts
rustyk
Does anyone sell just the bolts for hub adapters? One backed out, hit the frame and is bent up. Guess I could replace it with something similar as long as it's flush, and tight.:-||
Could check Home Depot. Or a hardware store that has a good bulk selection. Some adapters are standard threaded others are metric. Be sure to remove and bring a good one with you to compare.
Home Depot is the worst place to buy nuts and bolts. Try an ace hardware if you have em. Home despot will charge an arm and leg for small parts..
