how to calculate gearing?
Thewurst
I put my already motorized bike together, with a different motor and transmission reduction. (the one motor originally was a 7:1, the transmission I put on was a 3:1. As I expect it just stalls. Is there some sort of calculator that I can use to find the right sized sprocket for the rear?
or formula?
Ok thank you for that, I found a 60t sprocket on ebay that should bolt right up. This engine is off of a cateye pocket bike. I put a walboro carb with adjustable jets on it, so that should give it an edge of power. The calculator says it should go 49mph at 9500 rpms (2-stroke) with this sprocket, is it still geared too high? I assume so
Is this the bike from your previous thread, just with a different motor/trans? What size sprocket do you have on now? If 9500 rpm is your redline, I personally would shoot for a 40mph top speed. That should give you a comfortable 30ish mph cruising speed. I don't care what anybody says, 30 mph is fast on a bike that only has 2" wide tires.
can you post some pics of the bike the way it is now? 80t is massive IMO what top end does that give you at 95k?
That may be a good size. The 64 tooth is the largest I know of that is commonly available. I am running a 49cc 4 stroke on my build so I don't exactly know the power band of the little 2 strokes.
or formula?
Is this a pocket bike engine? Any pictures on your setup? If your transmission has 3:1, you might need 6:1 more reduction. So 3:1 x 6:1 = 18:1, which should work ok.
It'd be easier to use T8F pocket bike chain and sprockets. A 72t sprocket is about the size of a 48T bicycle sprocket. Use an 12t trans sprocket with 72t big sprocket to get 18:1. They have Chinese rear hubs with left side freewheel sprocket. The 4-hole 72t sprocket will bolt right on. Good luck.
At 45mph with 9500rpm, your gear ratio is 16.34:1. With this same ratio @ 30mph, rpms is at 6300rpm. Not bad. What size is your transmission sprocket?
