biknut
Hi everybody! I've been very concerned about vibration as well. I have investigated the crankshaft and found a few things that were wrong. First, the worst thing I found was that the crankshaft assembly had angular misalignment. All three engines that I have done had pretty much the same defect. As you probably know, the crankshaft is an assembly that is pressed together; well, for understandable reasons, when the assembly is pressed together, it is not perfect. If you were to put one of these crankshafts in a lathe and spin it, you would be shocked!, I mean really shocked! The misalignment is very pronounced. You don't need a dial indicator to see it; it is totally visible! The crankshaft ball bearings were never designed to operate in conditions like that. The angular misalignment also throws the flywheel weights off, so that just adds to the vibration. When I build an engine, I straighten the crankshaft, then take a skim cut to true up the flywheels. It is a quick way to get reliability from the engine. The bearings just cannot cope with the shaft torquing from side to side due to that angular misalignment. All the crankshafts I've seen are bent the same way, and I'm sure your crank is bent too! It's terrible! Another thing I would like to share with you all is that the flywheel weights are lightened from the factory on the connecting rod side. On the GT-5A (and I presume the GT-5SR as well) motors, you can see the drill holes, but on the older models, the flywheel weights are held in place by 3 screws. If you were to remove one of those weights, you will see that they milled some slots on the inside of those weights for balancing purposes, and when they are attached to the plates, you can't see them. I tried further lightening the flywheel weights on the connecting rod side, and it made the vibration worse. I might start selling reworked crankshafts for people who want to redo their engines, but don't have a machine shop. I predict I'll get to that in about a month.
Thanks,
-Fred
Yeah these cranks are the worst. Every one of them I've checked was off quite a bit. It's hard to find one that's even close to true.
Either your bearings go bad, or the bearing wobble around on their shafts, and wear out the block holes they're pressed into.
What I'm finding though, is it's surprisingly easy to adjust the crank with a hammer. It's easy to adjust, but that doesn't mean easy to make true.
So far I've only been looking at one shaft at a time. When I adjust one, it makes the other side go off. In a little while I'm going back to harbor slave and get another dial indicator so I can see both shafts at once. I hope that will help.
