copmagnet80cc
I'm ordering a new jug for my 66cc 2 stroke motor..I'm wondering how much I need to port on the intake, exhaust and tranfer ports...I've heard a few measurments to go by but just want ideas from all yall..thanks
So widen bolth ports about 1mm each side . Lower the intake 1mm and raise the exhaust 1mm, trim the skirt of the piston to clear the intake port at top dead center then mark the dome of the piston and add ramps for the transfers and wxhaust port jist file 1mm ramps down the edge. . . This allong with a high comp head and an x chamber will give u a powerfull bike that will be reliable reguardless of what carb and intake you ise
Well if you dont know how to use a deg wheel and do not know how to measure port timing then i sugest measuring down from the deck hight . A larger measurement from deck to exhaust roof wil net a lower power band and high static comp but a shorter measurement from deck to exhaist roof will net a higher rpm and lower static comp powerband
anyway if you want a high rpm midrange to high end power band bike and just want to hash it out beginer style and know its going to work then widen the exhaust port 1mm each side and rais the exhaust port roof 1mm do not lower it any then lower the intake port 1mm and widen it as far as you can and trim the piston skirt to clear the port at top dead center then add transfer port and exhaust port ramps to further alter the timing . . . Dont worry about cutting the piston i have taken a whole 1/4 in off the entire skort on the intake side and a added large ramps on the dome and it ran like a beast at high rpms . Then deck ur head way way down or buy a puch or fred head and raise the comp and a sbp exhaust is simple and effective tpo
