even with mods I have done to mine I doubt Im getting 5HP out of my engine
I doubt they are 2 HP stock
I think on my engine Ive helped the HP far more then the torque which is just moving the torque up higher into the RPMs
I can climb hills much faster but have to have the RPMs up higher to do so whereas before it would slow down to the torque spot
Im going to try an 18mm carb which I think will flatten out the bottom even more but add more to the top In the end a 15mm chainsaw carb with a 12mm venturi might do the best across the board
Im gona run down to the local chansaw shop tommarrow
the owner says he has some vintage carbs which will probably work well
have a great week
JAK
have a great week
JAK
