Out of a need to fiddle moreso that cheaper/more practical alternatives, I was walking around home depot looking for ways extend the muffler without a need to bend pipes or weld.
I came across a flexible copper water heater connector w 3/4 FIP and some 3/4" brass compression fittings. Thought this would be great until I found out the connector has a 180°F rating.
Then I found a braided stainless steel water heater connectors which I found are only rated to 200°F.
Then I found a steel braided water heater rubber tubing on amazon which is rated to 350°F.
It looks like rubber can handle higher temps. I've also seen an exhaust kit on SBP that uses rubber couplers. So is rubber really the way to go?
Can anyone suggest a working temp to shoot for regarding 66cc exhaust applications?
