Hold Piston Skirt
Uh you need to make sure the holes aren't where the exhaust are otherwise you'll have major problems with gas oil mix going out the exhaust and lowering your crankcase compression. Otherwise I've never used reeds and this could be beneficial but I'll let someone else talk to you about it
Drilling the intake skirt changes intake duration and will KILL power unless other mods are made to compensate. (reed valve and boost porting)
Unless you know what you're doing, this does nothing good.
Did you read the whole post lol? I did buy a reed and posted a link to a ported cylinder that might be worth buying.
didn't you see the big scratches in the bore? .......save your money........
oh an Excessive please shut up you make no sense at all with your rambling all you do is give people a headache..............
