salorr33cc
I have a GT5 66cc 38mm stroke engine with 160 miles on it, Run Bel Ray Synthetic oil 32:1 and a little bit of octane boost on Sunoco 93..
The problem is my motor wont rev past 7,560 rpm at 32.7 mph, have tach and speedo,when I first got the engine I took it apart and cleaned up the cylinder of any casting slag and port matched exhaust to Banana Pipe and intake to intake pipe, I also removed casting lip on transfer ports and widened exhaust and intake ports a hair on both sides,, I did not raise or lower anything,, I believe I got a pretty good motor cause it was pretty clean to begin with not to much to clean up ,, I also case matched the lower end where the cylinder meets lower gasket and case, trimmed gasket then beveled the case edges to gasket and lower part of cylinder jug so its an even flow,,
using only Banana pipe and stock slant head it 4-stroke like crazy,, under load or hill climb it would run better but still 4-stroking,, running really rich moved needle clip to top and did nothing, so I took a pointed center punch to the left side of main jet hole and tapped it to indent the soft brass fitting and close up hole a little and it worked,, engine ran better... any way to make a long story short I was able to rev out to 35.7 mph and still had more to go but let off due to breaking motor in still....
